Brief Description: Continued fitting left HS; counter sunk right spar
Completed testing rivets in all holes to assure that they would fit properly when it comes time to rivet. Fixed the problem with the aft spar not setting flush with the skin by increasing the size of the counter sunk holes. The smaller size work fine for the forward spar. Oh well. Spent a couple of hours on the center main rib before I got it to fit. Turned out that I need to get the flange perfectly square to the skin. It is still difficult to get the skin flush to the flange but it will go with presure. I ordered five special, screw down clecos I intend to use to put the skin tight to the spare when I rivet.Couner sunk the right spars and started to assemble it. It appears, unlike the left HS, the right side will fit will little addtional work. All my first efforts were on the left side. I guess I must have learned something when I moved to the right. Two long days fussing and fitting. Well, there should be less to do when I assemble and rivet.
