Left elevator: Some tricky situations were run into on the left elevator. The prepunched holes in the spar and rib webs didn't want to line up with the holes in the horn. Had to tweak some things to make it fit right.
Trying to line up the holes in the horn with the holes in the spar / rib.
Drilling out the trim servo access reinforcement plate to put the nutplates on.
