Justin Shumaker's Kitlog
Date:  2-7-2014
Number of Hours:  3.00
Brief Description:  Wing Tanks Step 4
In order for these fuel tanks to slide into the rear set of lightening holes I had to file away some material from the 2 ribs nearest the wing root on both wings. The filing took about 1 hour per wing. I used the hydraulic knockout to create a 3" hole centered around the fill port of each tank. I will design a fuel tank door. The rubber gaskets will arrive next week.
Filed ribs
Filed ribs
Hole for Fuel Door
Hole for Fuel Door
Getting Close to Done!
