Justin Shumaker's Kitlog
Date:  1-21-2014
Number of Hours:  5.00
Brief Description:  Left Wing Tip
For both wing tips I wanted to reinforce them by adding a couple layers of fiberglass and epoxy resin. I redrilled out all the 3/32 rivet holes with 3/16 nut plates. Now the wing tip is removeable. And to all the naysayers and aerodynamic purists, yes there is some additional drag due to the non countersunk screws! I am really looking forward to seeing how the wing tip lights look in the dark. The right wing tip still has another 20 hours before the epoxy is cured.
Drilled and Cleco'd
Drilled and Cleco'd
Nut Plates installed with Cherry Rivets
Torx #10-32 screws
Torx #10-32 screws
