Brief Description: Right Wing Cleaned and Reassembled
The right wing hardware was removed and replaced with new hardware. This includes the steel wing root and plate. Furthermore the bellcrank assemblies are now identical to one another. The hinge pins for the ailerons were cleaned and regreased. Lastly, the push rod was removed, cleaned, scrubbed and reinstalled. The result, half the friction and smooth quiet operation. The cotter pins were also installed in both the left and ring wing bellcrank assemblies.
