Brief Description: Right Wing Structural Preparation
Updrilled, marked the centerlines, straightened, and added wire conduit holes through ribs 8 to 14 for the right wing today. Deburred everything, and reassembled the right wing structure, ready for riveting.
Assembled the bearing to the Left wing aileron bellcrank, and bolted it into the mounting bracket on rib #9. The mounting bracket assembly will be riveted and bolted in place after the ribs are drilled and dimpled.
