Jeff & Jackie's RV-8 Project
Date:  10-4-2005
Number of Hours:  2.75
Manual Reference:  6-1
Brief Description:  HS Rear Spa
Shaped and cleaned up the second HS-609PP reinforcing spar. Only took two hours on this one. Man, I need to get some 400grit pads for the mouse sander so I don't have to do this by hand!!Matched drilled the two HS-609PP reinforcing spas to the HS-603PP rear spa channels. Marked which pieces go where with some light punch marks as per Vans recommendations. I just hope they're not so light that the primer covers them up completely!Have more or less decided now to make a jig for assembly. I need to do one for the wings still anyway, so I may as well do one now and use it for the empennage bits.
