Primered the instrumnet sub-panels, flange strip, the two aft fuselage side panels (I forget the part number; they go next to the passenger under the arm rests) and also the Whelan strobe PSU mount plate. Also riveted the ELT mount angles to the longerons inside the fuselage while waiting for primer to dry between coats. Cleaned up the workshop this morning too (though I didn't log that time).
