Match drilled the canopy hoop to the upper longerons. Cleco'd the forward baggage bulkheads to the F-802N. At this point I did some thinking and planning. I need to remove the existing bracket for the brake hoses and make a new one to hold the parking brake valve and the cable that will attach to the actuator arm. I also discussed access to the instrument panel with Jackie and she decided that yes, she does want me to do the access panel mod to the baggage bulkhead. So I need to do some additional research on the forums and come up with some sort of plan/design for that too.
