Jeff & Jackie's RV-8 Project
Date: 5-2-2008
Number of Hours: 3.50
Manual Reference: n/a
Brief Description: Tom Clark fastback - top skin (2)
Jackie and I had a good session drilling this evening. Man is it tight inside that fuselage, and I have the benefit of the extra space of the fast back!! ITs also quite cold in the shop today, and that hasn't done my cold any favours at all :-( Nonethe less, I'm very happy with the way this skin turned out in the end, even if it has cost me an estimated NZ $1100 to get right. All the bulkheads are now drilled, seat belt brackets drilled and basically the top skin is now all but done. I need to take it off, trim the edges back to their final size, ensuring correct edge distance for the rivets holes and then we can dimple, prime and rivet. Well, after the remaining 'inside fuse' work is done anyway,,,
