I'm away skydiving again this weekend, so I wanted to at least get *something* done tonight. I seem to be so busy at the moment...
Got the front seat floor fitted. Seperated and deburred the stiffeners. Minor panic while I couldn't locate the F-805C stiffener that goes between the two F-805D brackets. Fitted and drilled the front seat lower hinge half. A little later on, after dinner, I went back out deburred, edge-finished, assembled and fitted the passenger foot wells (which are located on either side of the front seat occupant). I then match-drilled the remaining #40 holes in the front seat floor before quitting (again) for the even.
