Didn't make quite as much headway as I'd have liked today. Basically, I got all the mid-section parts deburred and edge-finished, and cut out the relevant slots and holes in the left arm rest and bulk head for the rear set throttle. I haven't get cut the holes in the F-814 center section bulkheads. I'll do that later on when I have things cleco'd togerther and can run a string as per the instructions that come with the rear seat throttle kit. Before making a start of the F-823 side skins I made a start on rivetting the seat rib sub-assembly since we'd be needing it soon (see next post).
Hole cut in left bulkhead for rear seat throttle pushrod
