Jeff & Jackie's RV-8 Project
Date:  12-22-2006
Number of Hours:  1.00
Manual Reference:  n/a
Brief Description:  Right wing tip
Didn't get my .040 today, so did some more glasswork and stuff. The two reinforcing strips were a little short and didn't capture the end-most rivet of the nutplate at each end. To solve this I have built up layers of glass cloth around the end of the strip to the same level, and then placed a couple of larger pieces over the whole lot. This provides an equal level for the nutplate to sit on *and* completely captures the end of the reinforcing strip so it won't lift. Next up, I also replaced some glass at the very front of the nav/strobe light mounting plate where, again, I had a nutplate rivet edge-distance issue. I also drilled & countersunk for the nutplates on one side. Once all the glasswork has been done I'm going to re-prime the reinforcing plates in place since sanding the excess adhesive has removed some of the rattlecan primer. Once that is all done, then I can install all the nutplates. Lastly, the outside trailing edge of the wing tip will need to be filled and shaped.
Glassing the end of the reinforcing strip
Glassing the front of the light mount plate area
