A little tricky for just one person, but obviously do-able. Fitted the left wing tip. There's a little more trimming around the outboard hinge bracket to do, but otherwise the alignment and everything is good. Looks like there won't be nearly as much trimming of the trailing egde required. I'd put in some good time today, and Jackie arrived home just as I was drilling the last half dozen holes, so I finished up and called it quits for the day. Made some real good progress today and I'm well pleased. Now to clean that camera... :-(
