Went to the parachute club today but the wind was over limits for students. Otherwise a nice day. My only student went home at lunch time so I decided to head home as well and get some priming done while the sun was out. Cleaned & primered the top inboard wing skin and the wing walk doubler and realised I had mixed up way too much primer. Again! Quickly edge finished the fuel tank skin, dimpled the #8 screw holes and then cleaned. Masked off the outside skin and the inboard end rib and primered the aft side and outboard end. Went well up until I went to remove the masking tape which coiled up in a couple of places and touched on the barely dry primer, removing it and leaving a bare patch. Ah well, I still have to final leak test the access panel and then clean and primer that end, and I have to primer the top outboard skin so when I do those then I'll throw some more primer at the bare patches...
