Installed burner can to turbine. I had removed it to clean and polish. Spoke with Blake on proper assembly procedure. Next, carefully fit the tail-pipe to the burner can. This involves grinding a bevel on the tail-pipe so it will fit with just the right amount of friction into the burner. Looking for about 11/2 mm. space before clamping. On final assembly the angle of the pipe should clear the Right longeron by 4".
