JOHN'S WEB SITE
Helicycle
Trim fin alignment
Mounted Trim fin assembly to ship. Worked on the pitch and yaw parameters specified on the prints.
Drilled the 1/4" hole through the vertical fin to create 5 deg. positive pitch specified.
Started to adjust the vertical fin alignment.
Aligning fins
View from left side
Adjusting verticlal angle
F1 Rocket Evo Home
Helicycle Home
1065
Cabin Doors
Check-out and Airwor
Governor & RFI
Main Transmission
Rotor Blade
Swashplate
Swashplate
Tail Rotor
Trim Fins
Turbine engine
25
83
