Worked on Tail rotor pitch links. They need to be cut off shorter so as not to interfere when adjusting the Tail rotor pitch. Decided to weigh each link and file material off of the heavy ones. Was able to get within 1/10 gm. on all four.
Will contact Blake about painting the Tail rotor blades. They will probably need to be re-balanced due the weight of the paint applied.
