Worked on making the -3 AN stainless lines for brakes. We decided to use more robust brake lines to the back than the plastic flex tubing.l The tubing to the back through the keel is the same tubing used for the gear hydraulics. Both ends of the system are stainless flex hose. Also applied some more expoxy/flox to build up inside of right gear socket.
