RV-12
Date:  5-8-2012
Number of Hours:  5.00
Manual Reference:  49
Brief Description:  49 - Cooling System
Added a bead of high temp RTV around the edge of the cooler door (its easier to apply a layer of tape or adhesive plastic over the holes otherwise you press the RTV through the holes and the bead will be damaged when trying to release the door after curing).
Installed the radiator and oil cooler.
