Page 34-14/15 : placed all layers of fiberglass. Sides 5 layers, top 10 layers. The small layers are tricky. Be carefull otherwise they fall apart. I found it easier to wet out the layers first instead of placing them dry. I dyed the resin grey. The disadvantage of dyeing the resin is that it will be more difficult to spot airbubbles Next step is sanding till the first layer of tape, leaves a very nice edge. Page 34-16 : Opened the holes for the pivot bolts.
