Masked the canopy and the fuselage. Sanded the foam blocks and the plexi. Cut out the templates. "Bridging" the templates took some time. I measured the distance to the front fuselage at the end of the template. Used this distance to position wide tape in the middle of the canopy. From there to the templates (picture 2). Thereafter I was able to position the two layers of electrical tape. Next was sanding the plexi.
