RV-12
Date:  3-1-2010
Number of Hours:  5.00
Manual Reference:  21
Brief Description:  21 - Mid Fuse Ribs
Back from vacation to Austria.
Started with the baggage floors. I used two thin flush sets to set the AN470AD4-9. I had to drill two rivets out. Quite hard to squeuze them straight.
Installed the bearing bracket assemblies and the control column brackets. I received new ones from Van's after I had problems with the original ones. I initially had problems with the bearings but with the new brackets the installation was straight forward.
Page 21-14 step 1 is about installing the control column. Used some tape to hold the pair of washers.
21-03 step 3
21-03 step 3
21-03 step 8
21-03 step 8
21-14 step 1
21-14 step 1
