16-02 step 7 Terminal Block 16-03 step 1&2 ; Installed the stall warning subassembly to the nose rib 16-04 all steps ; two MS21042-08 nuts supplied, needed three
After installing the stall warning subassembly I tested it but no joy. No ground contact in the lower nutplate. Drilled the two flush rivets out and removed the primer. Reinstalled nutplate, problem solved.
