09-02 step5/6/7 HS-1213 Hinge bracket fabrication 09-02 step 8/9 HS-1209 Spar Cap Spacer fabrication 09-02 step 10 HS-1224 Doubler fabrication 09-02 step 1/2/3/4 Preparation of the spars/spar caps, used a doubler for countersinking.
Deburred all parts mentioned earlier.
09-07 Fabricated aft hinges HS-1218A-L&R 09-03 Clecoed parts of the spar box assembly 09-03 step 6 Final drill #30 WD1222 counterbalance brackets
A lot of deburring today. Had to cleco the spar box together just to see some progress. Seems that the WD-1207 & Wd-1208 control horns doesn't fit well; 3/32 gap (picture 3). Will contact Van's for that.
