RV-12
Date:  10-2-2009
Number of Hours:  0.00
Manual Reference:  16
Brief Description:  16 - Stall Warning
16-02 step 7 Terminal Block
16-03 step 1&2 ; Installed the stall warning subassembly to the nose rib
16-04 all steps ; two MS21042-08 nuts supplied, needed three
After installing the stall warning subassembly I tested it but no joy. No ground contact in the lower nutplate. Drilled the two flush rivets out and removed the primer. Reinstalled nutplate, problem solved.
Stall Warning
Stall Warning
Terminal Block
Terminal Block
