Brief Description: 27 - Rudder Pedals & Brake System
Used Fuel Lube as a pipe thread sealant. After a VAF posting of other builders having problems (leak) with Fuel Lube I took out the brass elbows. Cleaned all and used Loctite instead of Fuel Lube. Installed The Rudder system. With the fuselage still on his side works o.k.
