32-05 Control stick pushrods. Takes a lot of time to instal the nuts and washers. Used fuel lube to "glue" the steel washers to the rod. 32-06 Flaperon pushrods & flaperon torque arms. 32-08 Flap handle. Used the cover plate instead of a .025 shim. 32-11 Started with the rudder cables.
