Joels Web Site
Date:  2-4-2006
Number of Hours:  8.00
Manual Reference:  Misc
Brief Description:  Priming and Painting
I set up my new propane heater in the garage so I could get it warm enough to do some painting. I needed to touch up the gear axles and the motor mount from the drilling I did, I needed to prime the axle spacers, and I needed to paint the glareshield and the Van's NACa inlets. I finished painting the motor mount and axles and priming the axle spacers, but the other parts will need more coats to get a good finish. I also mounted the rudder pedals today and bolted on the engine mount. I still have to install the two lower machine screws on the bottom corners of the mount because the ones I had are too long. I ordered a pair of shorter screws that should work fine.
