Countersunk and dimpled right spar. reamed out bolt holes and installed bolts in right spar. This entry is an estimate of the work I did on the spar between the previous entry and the next entry. there are actually about three days or so of work I should have logged in January that I failed to document. this entry was added on February 9, 2005. The only item to note is that it took significantly less time to do the right spar than it did the left. Thank goodness for that.
