Drilled the two AN4 bolt holes in each of the attach blocks for the root attach assembly. I broke another 3/32 drill bit. It takes forever to drill these holes for some reason. Bolted the attach blocks for the end attach assemblies and drilled the pilot hole through the face of the blocks for the wing attach bolts.
