Fabricated ventral fin. This took a lot longer than I expected. This part has 6 bends in it, and I couldn't use my bending brake to make them. I think it turned out okay, though. I will finish putting it together once I have the rudder installed.The tail wheel install is simple in concept, but there is a fair amount of drilling involved. All the holes are drilled in steel or titianium. I spent quite a bit of time ensuring that I drilled the holes properly to keep the assembly properly aligned. I will have to remove the tailwheel to install the ventral fin, so I haven't fully tightened the nuts or installed a cotter pin to hold the castle nut in place.I started fabricating the fairing that is installed between the stabilators
