I have discovered a problem with my electronic ignition. It seems the front plugs are not firing. It looks like it might be a problem with whatever triggers the ignition module. I swapped wires to the two ignition modules, and by doing that I was able to get a spark on the fron plugs, so I know that both modules are okay and that my wiring is correct. I am going see what info I can get from Sonex.
