Joels Web Site
Date:  3-5-2006
Number of Hours:  6.00
Manual Reference:  F01
Brief Description:  Misc Riveting and Stuff
Michelle and I removed the wings today so that I could rivet the spar tunnel web and other miscellaneous fuselage parts in accordance with the F01 drawing. The side skins got a little bent in a couple areas around the spar tunnel opening, so I filed the openings to prevent that from happening again. I managed to run out of CCC44 rivets for the spar tunnel. I also ran out of the CCC42 rivets while riveting the tib rib on to the left wing. I ordered more, so I will just have wait until they arrive to finish up. I fitted the wing root seal I ordered from Van's to the left wing.
