Brief Description: Rear Spar Carrythrough and Misc
Worked on rear spar carrythrough assembly mostly. I put more coats of paint on the glareshield too. I think it looks pretty good now, with maybe a quick going over with 600 grit sandpaper after the paint has cured.I had to drill new cotter pin holes for the landing gear axle castle nut cotter pins. The holes I had drilled earlier were about 1/4 inch too far in. Oh well.
