Joe & Steve's RV9A Project
Date: 4-24-2018
Number of Hours: 0.00
Brief Description: wiring, VPX, AOA
Finalized airframe and sub-panel wiring, fixed a few issues and cleaned up the wire routing.
Installed the Odessy battery and fired up the VPX, hooked it to my laptop and configured all of the input and output circuit breaker and switch assignments. Was pretty easy and straightforward to do. Still need to set up flap travel, trim settings, etc., but need the control surfaces reinstalled first.
Installed the AOA display. Turns out there is only one location on the top of the panel that satisfied all of the requirement: far enough forward to clear the windscreen, far enough back so as to stay behind the panel, straight on view from the pilot seat, and not require cutting into stringers or sub-panel structure. Turned out great, looks good and passes the 'penny test'.
Power up the panel tomorrow!
Penny Test
