I finished covering the ailerons today. I used a different method to cover the ends. I left excess fabric hanging over the ends, cut it off at the top of the rib cap, then folded up the material from the bottom and glued it in place. Someone on the Just forum suggested this technique. It seems easier than covering the ends first, then covering the top and bottom surfaces like I did on the flaps.
