I fitted the left wing tip today. As usual, I spent a lot of time measuring and making a series of small cuts in the material. The fiberglass material was easy to cut with my Dremel tool. The manual calls for ¼” clearance from the aileron and it came out just about right. I suspect the right wing tip will go much faster.
