Brief Description: Covered doors with Polycarbonite
I covered both door frames with the polycarbonate supplied with the kit. Since I did not install the windows, I used a single piece to cover each door. The door frames a bowed slightly so I had to cut the material about 14 inches along the centerline/rear of each door. After removing some of the material I was able to join the two sides and make a seam along the center door frame. I drilled and cleacoed everything. I will attach the plastic to the door with rivets after fitting and trimming.
