Brief Description: Front and Rear Windshield Brackets
I installed the front and rear windshield brackets. There is no reference in the build manual on how to install these parts but I was able to get some guidance from the Builders Forum. I trimmed the material on each bracket to fit around the airframe tubing. I installed each bracket so the top was even with the top of the butt rib. I drilled them with a #30 bit, painted them and attached each with 1/8” aluminum rivets.
