I made a change to the panel that makes up the aft baggage bulkhead. I cut the panel in half and removed the top portion. I had a fabric panel made to cover the area open area. I installed the fabric with heavy duty marine snaps so it is easily removed. The bottom aluminum panel is installed with self-tapping screws as described in the build manual.
By making this mod I removed some weight and made access to the area behind the baggage much easier. Easier access is important because this is where I mounted my fuel pumps.
