Brief Description: Installed Rudder Pedal Assembly and Toe Brakes
I had previously fitted the rudder pedal assembly and then removed it for painting. I painted the rudder pedal assembly white and installed it again. I installed the toe brakes to the rudder pedal assembly using the bushings provided and riveted them in position withCCP44 rivets as described in the assembly manual.
