Assembled Horizontal Stab. Setting the fuselage up level and plumb was easier than I expected using the rotisserie provided by the previous owner Thanks Gary. Drilled insert post for forward attach bracket. Horizontal Stab has zero degrees incidence with fuselage.I set the symmetry of the horizontal and vertical stabalizers at 90 degrees. I made up the flying wires using the supplied attachment tabs, 3/32” wire, thimbles and Nicopress sleeves. All Nicopress sleeves checked with dial caliper set at .265”
Installed rudder assembly. Did not attach trim tab to left elevator because I can 't find the piano hinge. I'll buy another hinge and attach it later.
