I made a floor covering for the area over the control mixer. I used .020 aluminum and covered it with the same vinyl carbon fiber used on the instrument panel. I installed the controlled sticks and wired the radio PTT switches with handshake connectors. I did not finish the wiring with shrink wrap & cable sleeve because I’m going to have to install boot covers between the control sticks and the floor later. I installed the front floorboard that I made (hard to believe) four years ago. I installed cotter pins in the castle nuts for the wing attach bolts, rudder cables, etc.
