I installed LED landing lights on the front landing gear attach bracket. I bought the lights from Crazed Pilot along with a wig -wag flasher. I made mounts from angle aluminum. This would have taken much less time had I done it prior to mounting the landing gear. I had to remove the front landing gear bolts to mount the lights. The bolts are very tight and it took some tweaking to get everything back together.
