Brief Description: Continue with Horizontal Stiffener Spar
Drilled the remaining Stiffener. Mounted HS-411 and 412 and drilled. Clamped the bearing between two guides and drilled/cleco'd in place. Then matched bearing holes with bracket on Port side. Next step is to drill out the bearing brackets to match the casing.
