Brief Description: Attaching the Elevator's (Part 1)
Spent about an hour this evening getting the Elevator's ready to mount. Had some finish-up work to complete...stray rivets here and there, etc. Managed to get the Elevator's into position and secured with some temporary pins of my own making. I plan to order the Avery Alignment Pin's this afternoon as I feel they migh come in hand for the Rudder and Ailerons/flaps.
Tonight's efforts will be centered on trimming away the interference on the side of the Horizontal Stabilator. Not sure if I'll get much more done as I'm getting out of work quite late.
More to follow I'm sure...
Marked off trim piece.
Good alignment so far.
Looks good so far, but not sure about the spacing from the center-bearing.
