Brief Description: Riveted underside of Right Elevator
Just a one-hour stop on the way home from work. Temp. 17 degrees out. Riveted the underside of the Right Elevator with the Squeezer. Did everything I could with the standard yoke, but must come back tomorrow with the thin nose yoke. Actually, I might turn it over and continue on the top side to save time switching yokes back and forth.
Starting to pick up the pace a little now that Wing Kit is on the way. Need to finish this up asap.
Still undecided on the fiberglass tips. Not sure if I want to wait until the end of the project or not for all the fibreglass work.
