I fabricated 8 spacers I will use to better position the nuts and washers (washer not installed in pic) that are threaded onto the end of the retainer rods that hold the lower portions of the baffles around the lower cylinders. Without these spacers I fear the nuts and washers would ultimately crack the baffle at the bend radius. I installed the cooling blast tube on the left hand P-Mag and did various other FWF tasks.
