Brief Description: Engine sensor mount and gascolator planning.
I fabricated the angle bracket that supports the engine sensor mount and drilled the bolt holes through the firewall. Then I got to work planning the Gascolator installation. The Canadian MDRA insists on the incorporation of a Gascolator even with a fuel injected engine such as mine so I worked out a plan for installing one at the lowest possible point on the firewall.
